11 years agoUbuntu 14.04 Nios Build '_IFCHR' undeclared
Hi All:
Trying to build a new nios project on my Ubuntu system (14.04 64-bit) (Yes I know it's not an officially supported system). What I'm seeing is when I attempt compile any program, it appears the tools are pulling from the system header files which are not compatible with the software. specifically alt_fstat.c pulls /sys/stat.h which is getting pulled from /usr/include/x86_64-linux-gnu/sys/stat.h (There are others but this is the first) I think it's suppose to pull from one in the <installation directory>/nios2eds/bin/gnu area (there are 4 for quartus 15.0) Looking at the BSP Properties, it's pulling the includes by default from: /usr/include /usr/X11R6/include /usr/local/include and although I can add new once, I am unable to change any of these defaults. Anyone else seeing this? I know lots of you are running quartus on 14.04 but I haven't seen this error message. I know two of us here are seeing the same errors. Thanks Pete1 Reply
--- Quote Start --- Hi All: Looking at the BSP Properties, it's pulling the includes by default from: /usr/include /usr/X11R6/include /usr/local/include Pete --- Quote End --- Ok. I found the issue: The issue was an environment variable CPLUS_INCLUDE_PATH that set as part of our module setup. When that variable is not set, everything works. Pete
