21 years agoUboot + Stratix EP1S40 + nios2
I am trying to download the u-boot.bin file that I created using debian linux with gnu cross-compiler for uclinux. I am using nios-II command line utility program that comes with altera NIOS-II...
21 years agoHi Toysoldier,
Markus is correct, you need to use mk_target_board You should read Chapter 2 in "Nios II Flash Programmer User Guide" -- it is a very useful doc :-) http://www.altera.com/literature/ug/ug_nio..._programmer.pdf (http://www.altera.com/literature/ug/ug_nios2_flash_programmer.pdf) Regards, --Scott
