21 years agoUART with FIFO Buffer
Need to use UART with FIFO Buffer in SOPC Builder Nios II System: 1> The UART RS232 available in SOPC are without FIFO is it possible to add FIFO by modifying the same UART core 2> If not is ...
15 years agoIf you need an UART with buffers, you can try YANU Uart from opencores. Its interface is compliant to Altera Avalon Interfaces and, as I remember, is supported in U-Boot (if you need a bootloader, too).
