16 years agoUART use with Small newlib C Library
I want to add a UART to a minimal resources system. Stdin/out are used by JTAG Uart. Is there any way to utilise the standard UART using HAL if fopen and similar are unavailable? I'm quite h...
16 years agoMaking variables 'volatile' doesn't cause the data cache to be bypassed.
It is probably required [1] to ensure that all the memory transfers requested by the C source actually happen, and in the correct order. Passing -mno-cache-volatile to the compiler will cause it to use ldio/stio instructions for volatile data. But it would be more useful if this were a separate attribute. [1] judicious use of memory barriers [2] can have the desired effect. [2] eg asm volatile("\n":::"memory") tells gcc that any of memory might have changed - so it must not have memory cached in registers (and v.v.) across the statement.
