21 years agoUART related problem
hello everyone I am new to using NIOSII processor. I am trying out a simple program as a beginning to my project. I am using UP3 board and am trying to send and receive data through UART port. ...
21 years agoHi sourabh,
> i have assigned to the UART rx and tx. I have assigned them pins 42 and 47. Is that correct ?? This is correct for the UP3 Rev. 2 (1C6). > i am checking the result through hyperterminal For your initial testing, make sure flow-control is disabled and check your cable. On the UP3, the DB-9 connector is wired as DCE (e.g. RXD on pin2 and TXD on pin3, etc). Your PC RS-232 port is also DCE ... so you'll need a NULL modem. Regards, --Scott
