20 years agoUART max speed
SOPC builder allows for "other" baud rate entries than the standard, with only throwing up a Warning. I need an isolated link between 2 Nios CPUs, and among other solutions, I'm looking at ...
20 years agoIn Quartus II v6.0 Handbook -> embedded peripherals.
You could find this for UART baudrate configuration : divisor=int((clok freq/baudrate)+0.5) baudrate = clock freq / (divisor +1) You have to determine max clock freq of your design to determine max baud rate How to modify baudrate : ------------------------------- According to your clock freq and the baudrate you want, write into the divisor : IOWR_ALTERA_AVALON_UART_DIVISOR(uart_base_addr, new_divisor); don't forget to allow modification of divisor in SOPC Builder you can also read your divisor with IORD_ALTERA_AVALON_UART_DIVISOR.. You don't need to open a file descriptor on the uart IP device example : clock freq : 50Mhz baudrate : 921600 bds divisor = 54
