16 years agoUART loses bytes
Hi I have a problem with the uart: I can send single bytes from PC to FPGA and loop them back with out problem at baud rates up to 3MBd. But as soon as I write more than one byte at once or more...
16 years agoHow to physically wire the JTAG 10 pins to become a RS232 connector?
I understand that the RS232 must be converted to TTL, I have a tiny board that does so, and out put 4 pins, how to connect them to the JTAG 10 pins, and how to find which FPGA pins are connected to the JTAG pins? I am using Cyclone III Starter Board. I found this document (link below), does it help my problem? http://www.altera.com/literature/hb/cyc/cyc_c51013.pdf?gsa_pos=1&wt.oss_r=1&wt.oss=chapter%2013%20configuring%20cyclone%20iii Thanks in advance for your help.
