21 years agoUART ISR
Has Anyone implemented ISRs with AVALON UART? I'm trying to implement an ISR using the RRDY Interrupt bit in the STATUS register but it seems not work... has anyone an idea? i past a...
21 years agoNow SEEMS!! to be functioning...
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/laugh.gif I have noted that the IRQ call is not flushed after the ISR execution... http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/mad.gif In order to explain to the community I cut and paste the simple code I have created for my UART "SERIALE_EXT" peripheral I hope It will be usefull: ////////////////////////////////////////////////////////////////////////////////////////////////////////////////// # include <stdio.h># include "altera_avalon_uart_regs.h"# include "altera_avalon_uart.h"# include "sys/alt_irq.h"# include "system.h" // Register the istance into the CPU // ALTERA_AVALON_UART_INSTANCE( SERIALE_EXT, seriale_ext ); void handle_seriale_ext_interrupt (void *context, alt_u32 id); int _serial_rcv_exception; // ************************************************************************** // // ************************************************************************** // // MAIN Function // int main (void) { // Initialize the IRQ on the UART selected // ALTERA_AVALON_UART_INIT ( SERIALE_EXT, seriale_ext ); // Recast the _edge_capture pointer to match the alt_irq_register() // function prototype. void* serial_rcv_exception_ptr = (void*) &_serial_rcv_exception; // Register the interrupt handler. // alt_irq_register(SERIALE_EXT_IRQ, serial_rcv_exception_ptr, handle_seriale_ext_interrupt); } // END MAIN // // ************************************************************************** // // ************************************************************************** // // UART ISR Handling // void handle_seriale_ext_interrupt (void *context, alt_u32 id) { // Cast context to _edge_capture's type. // It is important to keep this volatile, // to avoid compiler optimization issues. volatile int* serial_rcv_exception_ptr = (volatile int*) context; // Store the value in the Serial exception register in *context. // *serial_rcv_exception_ptr = IORD_ALTERA_AVALON_UART_STATUS(SERIALE_EXT_BASE); // Reset the Serial exception register. // IOWR_ALTERA_AVALON_UART_STATUS(SERIALE_EXT_BASE, (*serial_rcv_exception_ptr & 0xFF7F)); // Print a simple message on the STDOUT peripheral // printf("\rISR HAS BEEN\nEXECUTED!!!"); } // END handle_serial_ext_interrupt // ////////////////////////////////////////////////////////////////////////////////////////////////////////////////// bye, shadowice
