22 years agoUART interrupt handler
Hello! Please, explain me how to write interrupt handler for UART using NIOS II IDE. I can't find any information in documentation about it. Please
20 years ago --- Quote Start --- originally posted by fischer@Aug 11 2006, 12:36 PM your problem will be
altera uart has no fifo buffer
921 kbit/s, that means (start bit+8 data bit + stopbit)
~ 92000 byte/s ->
~ every 10us will a receive interrupt be triggered and must
be handled before the next character arrives.
if any other interrupt in your system will run longer than 10us and you
do not work with nested interrupts, which is not quite simple,
then you will loose characters.
i think it's hard to get 115kbaud working, if you have other
interrupts running.
if you use e.g. opencores uart with fifo, the uart can receive 14 characters
until receive interrupt is triggert, this are ~140 us at 921 kbit/s.
you can run the uart at 921kbit/s, but if you get a continuous data stream,
you cannot handle this datastream with the altera uart.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=17533)
--- quote end ---
--- Quote End --- An Avalon UART with FIFO based on Altera Uart and available on SOPC builder : http://www.niosforum.com/pages/project_det...p_id=89&t_id=18 (http://www.niosforum.com/pages/project_details.php?p_id=89&t_id=18) It works for good reception without loosing char.. I still have some pb to send char at max speed 921Kbds : for instance I got only 8000 Byte/s with too very simple code :
fd = open(uart, O_RDWR | O_NONBLOCK);
while (1)
write(fd,(usigned char*)string,lenght);
