22 years agoUART interrupt handler
Hello! Please, explain me how to write interrupt handler for UART using NIOS II IDE. I can't find any information in documentation about it. Please
20 years ago --- Quote Start --- originally posted by mike desimone@Oct 20 2004, 12:53 AM i think the best thing you can do now is open the system library that the nios ii ide should have generated for you. if you look in there, you'll see the alt_sys_init code, and the system.h file that defines all the stuff you need to know about your sopc design.
if you look at the properties of your system library, you'll find a page which shows which uart that stdin/out/err are connected to. if that's the uart you want to talk to, then you can just use the standard posix routines printf, scanf, putc, getc, etc. to talk to the uart.
if that's not the uart you want to talk to, you can get its name from system.h. there should be a line like:
#define my_uart_name "/dev/my_uart"and you would then use my_uart_name as a filename to pass to open(), close(), read(), write(), etc.
if you're dead set on reinventing the wheel, and absolutely must write your own interrupt handlers/drivers/everything else, you want to name your main function as "alt_main" and not "main". this skips all the interrupt setup, alt_sys_init, etc. and it becomes your problem to write.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=2183)</div> --- Quote End --- I do like what you talk, but when I call "open(MY_UART_NAME,O_RDONLY)", the error message is that "O_RDONLY is undeclared ". can you tell me why and how to use open() function? if I can not open UART with open() function , I can not use the other function such as read(), write() and close(), and I can not communicate with nonblocking mode, right?
