19 years ago
UART in DE2 board
I'm trying to interface the DE2 board with the a pocket printer over
RS-232. It seems like the module requires CTS/RTS hardware flow
control in order to work correctly. I checked the pin assignments at
http://www.altera.com/education/univ/mater...-de2-board.html (http://www.altera.com/education/univ/mater...-de2-board.html)
and it looks like CTS/RTS pins are not there. Does that mean that
this board cannot implement CTS/RTS hardware flow control? Or is there a way to enable it somehow?
Thanks for any help you can provide.
1 Reply
    --- Quote Start ---
    originally posted by lili@Mar 26 2007, 10:03 AM
    hi,
    i'm trying to interface the de2 board with the a pocket printer over
    rs-232. it seems like the module requires cts/rts hardware flow
    control in order to work correctly. i checked the pin assignments at
    and it looks like cts/rts pins are not there. does that mean that
    this board cannot implement cts/rts hardware flow control? or is there a way to enable it somehow?
    thanks for any help you can provide.
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=22518)
    --- quote end ---
    --- Quote End ---
    Not that I&#39;ve checked the schematic for that board but if CTS and RTS are not routed then you will not be able to implement hardware flow control. If you have spare I/O to get at on the board and a level shifter you could manually wire it up. The level shifter will covert the FPGA I/O standard to what RS232 uses (+ or - 12V... I forget).
