Vincent_F
2 years agoUART gets stuck when enabling IRQ (NIOS II)
Hi, I'm reopening an old post from 2013 that apparently never got a reply. I'm facing the same problem. I have a small NIOS II system (used as a demo for my students) that features a jTAG UART an...
tehjingy_Altera
2 years agoHi
Could you try out the example design below on your board?
The example design is using uart in interrupt mode.
Jingyang, Teh
- Vincent_F2 years ago
Thanks for your reply. I can try your example but I can't see any source file. Could you check if the files or code were attached to your reply?
Best regards
Vincent
