20 years agouart functionally
hi if somebody want to try uart device , i post a simple code that's running of course it's not complete but i would like to start a common little project with all people write in...
20 years ago --- Quote Start --- originally posted by pmicro@Mar 22 2006, 02:02 PM it's uncredible how the world is absent
and how everybody anly ask and want
http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/blink.gif
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=13692)
--- quote end ---
--- Quote End --- this is the code i do rs232 interrupt... no hard feeling.. everyone is bz see how easily i can use the rs232 wth PIC uC... no need clear or set any flag, all is done by compiler (CCS C).. i dunno how u do in nios C
//date: 07/01/2006
//function: use PC to send 4 character to PIC and when the 4 character is detected as "ABCD" (ASCII), it echo back.
// : the "ABCD" sequence have to be correct or it will not echo back to PC.
# include <16F877A.h># fuses HS, NOWDT, NOPUT, NODEBUG, NOLVP, NOBROWNOUT, NOCPD, NOPROTECT, NOWRT# use delay(clock = 20000000)
# use rs232(baud=19200, xmit=PIN_C6, rcv=PIN_C7, ERRORS)
# INT_RDA //RS232 receive data available
void isr_rs232(){
int A_char, B_char, C_char, D_char;
int protocol; // use as a dummy to make sure the sequence of character received is correct.
A_char = getc();
if (A_char == 'A'){
protocol = 1;
if (protocol == 1){
B_char = getc();
if (B_char == '3'){
protocol = 2;
if (protocol == 2){
C_char = getc();
if (C_char == 'C'){
protocol = 3;
if (protocol == 3){
D_char = getc();
if (D_char == 'D'){
protocol = 4;
if (protocol == 4){
putc(A_char); putc(B_char); putc(C_char); putc(D_char); //echo back the character u send to your PIC
protocol = 0; //clear the dummy for further use.
void main(){
enable_interrupts(GLOBAL);
enable_interrupts(INT_RDA);
while(1){
; //do nothing and wait for rs232 interrupt
