20 years agouart functionally
hi
if somebody want to try uart device , i post a simple code that's running of course it's not complete but i would like to start a common little project with all people write in this community . # include "count_binary.h" int val; int uart_0; char buf[255]; alt_u8 counter; // REGISTER static void handle_uart_interrupt(void* context,alt_u32 id) { val++; //everytime i receive a caracter increment and display on leds Write_Output(val); //using this macro automatically bit ready to receive will be resetted //and ready for a new interrupt when shifter register finish to translate last bit //in the uart device buf[counter]=IORD_ALTERA_AVALON_UART_RXDATA(UART_0_BASE) ; counter++; if (counter==6) {printf("riceived:%s\r ",buf); counter=0; } } static void Write_Output(alt_u8 val) { IOWR_ALTERA_AVALON_PIO_DATA(PM_OUT_BASE, val); } int main(void) { int i; volatile int uart_0; val=0; while( 1 ) { IOWR_ALTERA_AVALON_UART_CONTROL(UART_0_BASE, 0x180); alt_irq_register(UART_0_IRQ,&uart_0,handle_uart_interrupt); } return(0); } i use vc#.net to send a string ("walter") of 6 caracters . In Nios II ide console is displaying as follows received:walter i think this sample will be good for many people want to start to use uart device and interrupt . I stay 2 days reading and trying to gain this , i'm not clever . Of course need to implement also transmit interrupt and create a protocol but if other people contribute to continue it's possible to obtain very interesting development ciao walter2 Replies
it's uncredible how the world is absent
and how everybody anly ask and want http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/blink.gif - Altera_Forum
--- Quote Start --- originally posted by pmicro@Mar 22 2006, 02:02 PM it's uncredible how the world is absentand how everybody anly ask and want
http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/blink.gif
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=13692)
--- quote end ---
--- Quote End --- this is the code i do rs232 interrupt... no hard feeling.. everyone is bz see how easily i can use the rs232 wth PIC uC... no need clear or set any flag, all is done by compiler (CCS C).. i dunno how u do in nios C
//date: 07/01/2006 //function: use PC to send 4 character to PIC and when the 4 character is detected as "ABCD" (ASCII), it echo back. // : the "ABCD" sequence have to be correct or it will not echo back to PC. # include <16F877A.h># fuses HS, NOWDT, NOPUT, NODEBUG, NOLVP, NOBROWNOUT, NOCPD, NOPROTECT, NOWRT# use delay(clock = 20000000) # use rs232(baud=19200, xmit=PIN_C6, rcv=PIN_C7, ERRORS) # INT_RDA //RS232 receive data available void isr_rs232(){ int A_char, B_char, C_char, D_char; int protocol; // use as a dummy to make sure the sequence of character received is correct. A_char = getc(); if (A_char == 'A'){ protocol = 1; } if (protocol == 1){ B_char = getc(); if (B_char == '3'){ protocol = 2; } } if (protocol == 2){ C_char = getc(); if (C_char == 'C'){ protocol = 3; } } if (protocol == 3){ D_char = getc(); if (D_char == 'D'){ protocol = 4; } } if (protocol == 4){ putc(A_char); putc(B_char); putc(C_char); putc(D_char); //echo back the character u send to your PIC } protocol = 0; //clear the dummy for further use. } void main(){ enable_interrupts(GLOBAL); enable_interrupts(INT_RDA); while(1){ ; //do nothing and wait for rs232 interrupt } }
