21 years agoUART Core with CTS/RTS
In a working design I configured my UART core so that it uses CTS/RTS. But I do not get a simple design running that shall only send integers from a Windws hyperterminal to via the Nios core an...
21 years ago --- Quote Start --- originally posted by badomen@Jun 23 2005, 11:12 AM i learned a new term reading this post so now i'm curious..... what is "clean" cts/rts mode? (i know flow control but what do you mean by "clean"???). by clean if you mean a clean signal ........ rs232 has never been known to be "clean". --- Quote End --- Hej BadOmen, with "clean" I meant that only the CTS/RTS and TxD and RxD are used. It is maybe a strange and unofficial term, but since i now have problems with tools like "Hyperterminal" and also "Matlab", where you just specify "FlowControl = Hardware" and do not really know, which pins take part in the communication, I think the term is justified... (When assigning CTS/RTS in a more advanced terminal program, the communication works). By the way, maybe someone has a experiences with Matlab and CTS/RTS-communication with Nios. I read the Matlab documentation, but did not get it working. Here are my matlab commands (but I tried other as well): >> s2 = serial('COM2'); >> set(s2, 'BaudRate', 115200); >> set(s2, 'FlowControl', 'hardware'); >> set(s2, 'DataTerminalReady', 'off'); >> fopen(s2) >> fprintf(s2, '%d', 3); Matlab "freezes" after execution of these commands... So, if somebody has a good idea, it would be great...
