21 years agoUART Core with CTS/RTS
In a working design I configured my UART core so that it uses CTS/RTS. But I do not get a simple design running that shall only send integers from a Windws hyperterminal to via the Nios core an...
21 years agomake sure you set the tx fifo in the com port properties to 1. Do this through control panel - system - device manager.
This is because, when it's more than 1 (typically 14/16), the PC continues to send data after you raise CTS. It continues until its FIFO is emptied. Thus you would experience Rx overruns on your embedded device.
