16 years agou-boot
I am trying to boot a kernel with u-boot, but don't seem to be getting anywhere. I've built u-boot from the nios2-generic branch according to http://nioswiki.com/dasuboot
It runs and things seem to basically work, including jffs2, but not ethernet. What I am trying to do to test is: 1) program the kernel into flash with nios2-flash-programmer 2) load u-boot using nios2-download 3) boot the kernel image from flash I've tried a few variations on this with the various images that are generated by the build. The last iteration went like this:$ mkimage -A nios2 -O linux -T kernel -C none -a 0xc0000000 -e 0xc0000000 -n "linux" -d /data/nios/nios2-linux/uClinux-dist/linux-2.6.x/arch/nios2/boot/vmlinux.gz vmlinux.img
Image Name: linux
Created: Tue Mar 30 11:32:16 2010
Image Type: NIOS II Linux Kernel Image (uncompressed)
Data Size: 4423821 Bytes = 4320.14 kB = 4.22 MB
Load Address: 0xC0000000
Entry Point: 0xC0000000
$ bin2flash --base=0xc4000000 --end=0xc4ffffff --location=0x200000 --input=vmlinux.img --output=vmlinux.img.flash
$ nios2-flash-programmer --mmu --base=0x4000000 vmlinux.img.flash --instance 1
$ nios2-download -g u-boot --instance 1 && nios2-terminal
Using cable "USB-Blaster ", device 1, instance 0x01
Processor is already paused
Initializing CPU cache (if present)
OK
Downloaded 153KB in 1.3s (117.6KB/s)
Verified OK
Starting processor at address 0xC1F80000
nios2-terminal: connected to hardware target using JTAG UART on cable
nios2-terminal: "USB-Blaster ", device 1, instance 0
nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate)
U-Boot
==> iminfo 0xc4200000
# # Checking Image at c4200000 ...
Legacy image found
Image Name: linux
Data Size: 4423821 Bytes = 4.2 MB
Load Address: c0000000
Entry Point: c0000000
Verifying Checksum ... OK
==> bootm 0xc4200000
# # Booting kernel from Legacy Image at c4200000 ...
Image Name: linux
Loading Kernel Image ... OK
OK
bootargs=<NULL> @ 0xc1f3fd94
initrd=0x0-0x0 It doesn't do anything else after that. With this image I would expect it to start booting, then complain about a missing, like it does if I download the image directly ("Kernel panic - not syncing: No init found. Try passing init= option to kernel."). With some other things I've tried, for example by using zImage, u-boot gives an error like this: Loading Kernel Image ... OK
OK
initrd=0x0-0x0
*** ERROR: unimplemented instruction @ c1700000
# ## ERROR# ## Please reset board# ##1 Reply
I updated the git and wiki, and added a new page,
http://nioswiki.com/extrem_guide_to_kill_neek_with_u-boot Please try again. - Hippo
