15 years agoU-Boot v2 aka Barebox
Hello, I'm inviting you to try this wonderfull bootloader named Barebox (here (http://barebox.org)). I added the nios2 arch to the project some times ago and now, we have some nios2 drivers ava...
13 years agoHi,
I wake-up agin this thread :) Our design change, and now include a mmu support (instead mpu). I update barebox config, add MMU support, but keep all previous settings. Unfortnatly, barebox don't start anymore ( no console print, even with log level and early printf). Other baremetal applications (MemTest...) from altera keep working, and linux manage to boot. I try to trace it with gdb (via jtag cable). It keeps looping on arch/nios2/cpu/start.S, between "EXCEPTION TRAMPOLINE" and "initd 0(R6)" /* EXCEPTION TRAMPOLINE -- the following gets copied
* to the exception address (below), but is otherwise at the
* default exception vector offset (0x0020).
_except_start:
movhi et, %hi(_exception)
ori et, et, %lo(_exception)
jmp et
_except_end:
/* INTERRUPTS -- for now, all interrupts masked and globally
* disabled.
wrctl ienable, r0 /* All disabled */
/* DCACHE INIT -- if dcache not implemented, initd behaves as
* nop.
movhi r4, %hi(DCACHE_LINE_SIZE)
ori r4, r4, %lo(DCACHE_LINE_SIZE)
movhi r5, %hi(DCACHE_SIZE)
ori r5, r5, %lo(DCACHE_SIZE)
mov r6, r0
1: initd 0(r6) <-- When reach here, jump to _except_start
add r6, r6, r4
bltu r6, r5, 1b Any idea or suggestions ? Regards, Christophe
