15 years agoU-Boot v2 aka Barebox
Hello, I'm inviting you to try this wonderfull bootloader named Barebox (here (http://barebox.org)). I added the nios2 arch to the project some times ago and now, we have some nios2 drivers ava...
13 years agoHi,
Thanks Franck for your response (and for your work on Barebox / Nios 2). I already change PHY address to 0 (or -1), else, I got an error about unknown PHY id. We have made some progress. According to the design, we have to use dedicated memory descriptor. So, I complete in generic.c (well, a copy for this file for the DK board) the description, (tse_mac) with a new entry. Now, I can see TX LED activity, but, unfortunatly, server don't seems to proceed the Frame (maybe the frame is wrong, and dropped). I enable trace in barebox altera_tse driver. I see several sgdma TX. First one has status 0xC, and following have 0x1C, until timeout. I'll try to dump packet, and check if it's correct. Edit : In MAC Registers about status, aAlignmentErrors increase (when server perform a broadcast ping). Packet dump shows something similare. To be Continue. Regards, Christophe
