20 years agou-boot on the nios2 eval baord
Has anyone ported u-boot to the NIOS2 eval board?
20 years ago> Why would full feature use a 66MHZ clok and standard uses a 80MHZ clock?
> Does the number of functional blocks determine the clock speed and if so, why? As more "area" is consumed by your design, it becomes increasingly difficult to route signals through the available interconnect paths. When things get crowded, critical paths get longer and propagation delays increase -- so you have to slow down the clock to meet the required setup, hold, etc. times. > I have lift off, but only on the JTAG UART. Great! Regards, --Scott
