20 years agou-boot on the nios2 eval baord
Has anyone ported u-boot to the NIOS2 eval board?
20 years ago --- Quote Start --- originally posted by smcnutt@Apr 14 2006, 12:09 PM > are you sure it's 80mhz. i seem to recal seeing 66mhz in sopc builder.
ok ... i've been looking at the 'standard' configuration ... which is 80 mhz. if you're
using the 'full featured' configuration, then 66 mhz is correct.
regards,
--scott
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14391)
--- quote end ---
--- Quote End --- Ok Scott, I have lift off, but only on the JTAG UART. Thanks for your help. Next task, get the _real_ UART working...
