20 years agou-boot on the nios2 eval baord
Has anyone ported u-boot to the NIOS2 eval board?
20 years ago --- Quote Start --- originally posted by smcnutt@Apr 13 2006, 11:50 AM hi fmcmurra,
which evalutation board are you using? there are several "nios ii" eval boards.
porting is quite simple ... so even if a port does not exist, you can usually just
use an existing nios ii board configuration with a few nips 'n tucks to the config
header file and have a working u-boot. see:
http://forum.niosforum.com/forum/index.php...indpost&p=13700 (http://forum.niosforum.com/forum/index.php?act=st&f=18&t=3571&hl=&view=findpost&p=13700)
regards,
--scott
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14344)
--- quote end ---
--- Quote End --- Hi Scott, Should I be using the offsets that are in the system.h file that's located in my project softaware subdirectory?
