20 years agou-boot on the nios2 eval baord
Has anyone ported u-boot to the NIOS2 eval board?
20 years agoHi fmcmurra,
Which evalutation board are you using? There are several "Nios II" eval boards. Porting is quite simple ... so even if a port does not exist, you can usually just use an existing Nios II board configuration with a few nips 'n tucks to the config header file and have a working u-boot. See: http://forum.niosforum.com/forum/index.php...indpost&p=13700 (http://forum.niosforum.com/forum/index.php?act=st&f=18&t=3571&hl=&view=findpost&p=13700) Regards, --Scott
