16 years ago
U-Boot DIV64 Issue
I just made u-boot works with Ethernet and Flash access and try to boot the linux kernel. but there is an error exception.
--- Quote Start ---
==> imi e8060000
# # Checking Image at e8060000 ....
Legacy image found
Image Name: test
Image Type: NIOS II Linux Kernel Image (uncompressed)
Data Size: 3371311 Bytes =
*** ERROR: unimplemented instruction @ c7fd5764# ## ERROR# ## Please reset board# ##
--- Quote End ---
after tracing the code, i found the error is caused by an 64bit-divide-64bit operation.
display_options.c in u-boot/lib/
--- Quote Start ---
void print_size(unsigned long long size, const char *s)
unsigned long m = 0, n;
static const char names[] = {'E', 'P', 'T', 'G', 'M', 'K'};
unsigned long long d = 1ULL << (10 * ARRAY_SIZE(names));
char c = 0;
unsigned int i;
n = size / d; <=== error generated here
--- Quote End ---
Since there is no any warning/error message during u-boot compile.
Does anyone have any suggestion ?
    I think kernel toolchain may be linking in glibc code for the div64 function. I don't know why the glibc code doesn't work in U-Boot (or why this would suddenly change).
    I ran in to something similar with mul64 recently. I worked around it by implementing my own mul64, so it wouldn't try to link in the glibc version.
    Pinta, thanks for the clue.
    jhwu0625, I added gcc4 support, please pull.
    - Hippo
