20 years ago
u-boot custom commands
In response to:
http://forum.niosforum.com/forum/index.php...indpost&p=15096 (http://forum.niosforum.com/forum/index.php?showtopic=3837&view=findpost&p=15096)
> How to add your cumstom commands into the u-boot?
First read: doc/README.commands -- the file has many interesting details. But
to summarize:<div class='quotetop'>QUOTE </div>
--- Quote Start ---
Commands are added to U-Boot by creating a new command structure.
This is done by first including command.h
Then using the U_BOOT_CMD() macro to fill in a cmd_tbl_t struct.
U_BOOT_CMD(name,maxargs,repeatable,command,"usage","help")
name: is the name of the commad. THIS IS NOT a string.
maxargs: the maximumn numbers of arguments this function takes
command: Function pointer (*cmd)(struct cmd_tbl_s *, int, int, char *[]);
usage: Short description. This is a string
help: long description. This is a string
[/b]
--- Quote End ---
A good example of a custom command is the &#39;epcs&#39; command
(cpu/nios2/epcs.c). This is a Nios II custom command. However, you can create
board-specific custom commands by following the same process in your board&#39;s
source tree.
> where is the source code for the command "cp" ? and so on...
Most generic u-boot commands are found in the &#39;common&#39; tree. You can grep
for "U_BOOT_CMD" to find where all of the commands are implemented. The
&#39;cp&#39; command is implemented, for example, in common/cmd_mem.c.
--Scott
