19 years agoU-Boot-1.1.5 released
Please find the update in sourceforge.net .
http://sourceforge.net/projects/u-boot/ (http://sourceforge.net/projects/u-boot/) But it seems the www.denx.de site was down. (I haven't tried it yet)5 Replies
Hi Hippo,
I built a few configurations last night -- everything builds fine ... I haven't tested the images yet. But I don't anticipate any problems -- there weren't any significant changes to the Nios II trees. Best Regards, --Scott - Altera_Forum
--- Quote Start --- originally posted by smcnutt@Nov 4 2006, 01:24 AM hi hippo,i built a few configurations last night -- everything builds fine ... i haven't
tested the images yet. but i don't anticipate any problems -- there weren't
any significant changes to the nios ii trees.
best regards,
--scott
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=19154)
--- quote end ---
--- Quote End --- Yes, I can't find any improvement for Nios II. :< too bad. I had added "bootargs" patches to both kernel and u-boot to pass kernel command line, please check them on the Nios wiki. I didn't check them, yet. Cound you please check out, and let me know if it works or not? Thank you. Hippo
Hi Hippo,
> I had added "bootargs" patches to both kernel and u-boot to pass kernel command line, > please check them on the Nios wiki. This will be very helpfl. > I didn't check them, yet. > Cound you please check out, and let me know if it works or not? Ok. BTW: We should discuss this off-line. There are several things that, IMHO, need improvement. Passing the command line was one -- thanks for doing that. Two other 'priority' features are -- passing the board info structure to the kernel (from a bootloader). -- passing the ramdisk address to the kernel (from a bootloader). Basically, use a strategy similar to PowerPC embed_config ... or the flat device tree ... I'd like to see the nios2_system.h file go away ;-) Regards, --Scott - Altera_Forum
--- Quote Start --- originally posted by smcnutt@Nov 7 2006, 10:23 PM hi hippo,> i had added "bootargs" patches to both kernel and u-boot to pass kernel command line,
> please check them on the nios wiki.
this will be very helpfl.
> i didn't check them, yet.
> cound you please check out, and let me know if it works or not?
ok.
btw: we should discuss this off-line. there are several things that, imho, need improvement.
passing the command line was one -- thanks for doing that. two other 'priority' features are
basically, use a strategy similar to powerpc embed_config ... or the flat device tree ...
i'd like to see the nios2_system.h file go away ;-)
regards,
--scott
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=19265)
--- quote end ---
--- Quote End --- I had tried to pass initial ramdisk address about one year ago. But I did not success, then I used initramfs. I shall look at it again. It should be easier to me now.
Updated for initrd support. not tested yet.
u-boot patch ver2, uClinux-dist patch ver14.
