20 years agoU-BOOT !!!!!!!!!!!!
Hi http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/wacko.gif ,
that u-boot is really driving me crazy. This is what I've done: 1- Compiled u-boot (got the .bin and the .srec) 2- Used flash programmer to program the .bin in flash (user zone) 3- Used quartus programmer to program standard.sof 4- Followed those instructions in the Using.txt But everytime I launch the nios2-console I get an error messageCommunication port must be specified.
Use openport <port> to configure the communication port. And I'm totally lost within that, It's by God bless that I succeded to write this topic Please rescue me52 Replies
I was thinking of my problem with u-boot/µClinux, and suddenly I got this view: normally to get µClinux working we got to program the nios2linux design in the FPGA firstly. So considering my situation: I programmed the standard design in the user zone of flash so to get it launched every time with no intervention and I programmed the u-boot in offset 0 of the flash. This way I've got u-boot lauched automatically. But if I'm using the last to launch µClinux, don't I need that sof of nios2linux ! Obviously yes, but I don't want to use quartus programmer, and I can't convert the linux_time_lmited.sof to .flash to program it into flash for once, and even if I could, at which offset will I do !!!!!!!!!!!!!! I'm really confuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuused http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/blink.gif - Altera_Forum
Hi Scott,
<div class='quotetop'>QUOTE </div> --- Quote Start --- Could you explain your memory organization (what RAM/SDRAM you have and where it's located)[/b] --- Quote End --- *SRAM (2x512 KB): 0x0200_0000 --> 0x020F_FFFF *SDRAM (16 MB): 0x0100_0000 --> 0x01FF_FFFF I've programmed the 1s40 standard sof in user config zone of flash (0x0040_0000) so I don't have to use everytime the quartus programmer and u-boot in 0x0000_0000 <div class='quotetop'>QUOTE </div> --- Quote Start --- ... and what is the exception address (I'm assuming it's 0180_0020 ... otherwise the kernel would go belly up on the first interrupt after nios2-download).[/b] --- Quote End --- Sorry, but I don't know how nor where to get that. <div class='quotetop'>QUOTE </div> --- Quote Start --- Also, the kernel image you're using is compressed ... so please post the objdump of the uncompressed kernel image -- that's the one I need to see. When you use this image you should use '-C none' with mkimage (since the kernel will decompress itself).[/b] --- Quote End --- After a strip:$ nios2-elf-objdump -h vmlinux vmlinux: file format elf32-littlenios2 Sections: Idx Name Size VMA LMA File off Algn 0 .text 0016f840 01000000 01000000 00000094 2**3 CONTENTS, ALLOC, LOAD, READONLY, CODE 1 .data 0000e7c0 0116f840 0116f840 0016f8d4 2**2 CONTENTS, ALLOC, LOAD, DATA 2 .init 0006bbb8 0117e000 0117e000 0017e094 2**2 CONTENTS, ALLOC, LOAD, CODE 3 .bss 00015318 011e9bc0 011e9bc0 001e9c4c 2**4 ALLOC 4 .sbss 00000032 011feed8 011feed8 001e9c4c 2**0 ALLOC, SMALL_DATA 5 .eram 00000000 02000000 02000000 001e9c4c 2**0 CONTENTS 6 .romfs.data 00000000 00200000 00200000 001e9c4c 2**0 CONTENTS 7 .comment 0000189c 00000000 00000000 001e9c4c 2**0 CONTENTS, READONLY
<div class='quotetop'>QUOTE </div> --- Quote Start --- Could you also please post the header objdump of u-boot (you can strip it first -- nios2-elf-strip).[/b] --- Quote End ---$ ./mkimage -d vmlinux.bin -A nios2 -O linux -T kernel -n "Welcome to uClinux with MFM" -a 01200000 -e 01200000 -C none vmlinux.img Image Name: Welcome to uClinux with MFM Created: Fri May 12 04:51:42 2006 Image Type: Nios-II Linux Kernel Image (uncompressed) Data Size: 2005944 Bytes = 1958.93 kB = 1.91 MB Load Address: 0x01200000 Entry Point: 0x01200000 /cygdrive/d/u-boot-src/u-boot/mkimage $$ nios2-elf-strip u-boot /cygdrive/d/u-boot-src/u-boot $ nios2-elf-objdump -h u-boot u-boot: file format elf32-littlenios2 Sections: Idx Name Size VMA LMA File off Algn 0 .text 000169a1 01fc0000 01fc0000 00000094 2**4 CONTENTS, ALLOC, LOAD, READONLY, CODE 1 .u_boot_cmd 000003a8 01fd69a4 01fd69a4 00016a35 2**2 CONTENTS, ALLOC, LOAD, DATA 2 .data 00000a2c 01fd6d4c 01fd6d4c 00016ddd 2**2 CONTENTS, ALLOC, LOAD, DATA 3 .bss 00003eb4 01fd7780 01fd7780 00017809 2**2 ALLOC 4 .comment 000007ba 00000000 00000000 00017809 2**0 CONTENTS, READONLY /cygdrive/d/u-boot-src/u-boot $
