Hi Scott,
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
If you're using Nios 5.1 and the 1s40 standard configuration, your flash base address should
be 0000_0000.[/b]
--- Quote End ---
I'm using Nios II 5.0 and 1s40 standard configuration.
--- Quote Start ---
The best bet is to follow mountain8848's suggestions and review your ptf file[/b]
--- Quote End ---
That's right I found the correct information there.
--- Quote Start ---
> Bank# 1: Size: 0 KB in 0 Sectors
Check your flash_init() routine in board/altera/common/AMDLV065D.c -- you probably still have
the routine contents commented out -- I believe that's what I suggested you do to get started
on the other board you were using (since you were using a different flash device). Normally,
u-boot will report an error if flash_init() reports zero memory.[/b]
--- Quote End ---
That's already done without my intervention, this is the content of the AMDLV065D.c file:
* (C) Copyright 2000-2004
* Wolfgang Denk, DENX Software Engineering, wd@denx.de.
* See file CREDITS for list of people who contributed to this
* project.
* This program is free software; you can redistribute it and/or
* modify it under the terms of the GNU General Public License as
* published by the Free Software Foundation; either version 2 of
* the License, or (at your option) any later version.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with this program; if not, write to the Free Software
* Foundation, Inc., 59 Temple Place, Suite 330, Boston,
* MA 02111-1307 USA
# include <common.h># if defined(CONFIG_NIOS)# include <nios.h># else# include <asm/io.h># endif
# define SECTSZ (64 * 1024)
flash_info_t flash_info;
unsigned long flash_init (void)
return (CFG_FLASH_SIZE);
void flash_print_info (flash_info_t * info)
int i, k;
int erased;
unsigned long *addr;
printf (" Size: %ld KB in %d Sectors\n",
info->size >> 10, info->sector_count);
printf (" Sector Start Addresses:");
for (i = 0; i < info->sector_count; ++i) {
/* Check if whole sector is erased */
erased = 1;
addr = (unsigned long *) info->start;
for (k = 0; k < SECTSZ/sizeof(unsigned long); k++) {
if ( readl(addr++) != (unsigned long)-1) {
erased = 0;
break;
/* Print the info */
if ((i % 5) == 0)
printf ("\n ");
printf (" %08lX%s%s",
info->start,
erased ? " E" : " ",
info->protect ? "RO " : " ");
printf ("\n");
int flash_erase (flash_info_t * info, int s_first, int s_last)
unsigned char *addr = (unsigned char *) info->start;
unsigned char *addr2;
int prot, sect;
ulong start;
/* Some sanity checking */
if ((s_first < 0) || (s_first > s_last)) {
printf ("- no sectors to erase\n");
return 1;
prot = 0;
for (sect = s_first; sect <= s_last; ++sect) {
if (info->protect) {
prot++;
if (prot) {
printf ("- Warning: %d protected sectors will not be erased!\n",
prot);
} else {
printf ("\n");
/* It's ok to erase multiple sectors provided we don't delay more
* than 50 usec between cmds ... at which point the erase time-out
* occurs. So don't go and put printf() calls in the loop ... it
* won't be very helpful;-)
for (sect = s_first; sect <= s_last; sect++) {
if (info->protect == 0) { /* not protected */
addr2 = (unsigned char *) info->start;
writeb (addr, 0xaa);
writeb (addr, 0x55);
writeb (addr, 0x80);
writeb (addr2, 0x30);
/* Now just wait for 0xff & provide some user
* feedback while we wait.
start = get_timer (0);
while ( readb (addr2) != 0xff) {
udelay (1000 * 1000);
putc ('.');
if (get_timer (start) > CFG_FLASH_ERASE_TOUT) {
printf ("timeout\n");
return 1;
printf ("\n");
return 0;
* Copy memory to flash, returns:
* 0 - OK
* 1 - write timeout
* 2 - Flash not erased
int write_buff (flash_info_t * info, uchar * src, ulong addr, ulong cnt)
vu_char *cmd = (vu_char *) info->start;
vu_char *dst = (vu_char *) addr;
unsigned char b;
ulong start;
while (cnt) {
/* Check for sufficient erase */
b = *src;
if ((readb (dst) & b) != b) {
printf ("%02x : %02x\n", readb (dst), b);
return (2);
writeb (cmd, 0xaa);
writeb (cmd, 0x55);
writeb (cmd, 0xa0);
writeb (dst, b);
/* Verify write */
while (readb (dst) != b) {
if (get_timer (start) > CFG_FLASH_WRITE_TOUT) {
return 1;
dst++;
src++;
cnt--;
return (0);
