20 years agoU-BOOT !!!!!!!!!!!!
Hi http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/wacko.gif , that u-boot is really driving me crazy. This is what I've done: 1- Compiled u-boot (got the .bin and the .srec)...
20 years agoHi MFM,
> seemingly my flash base adress is 0x800000, don't ask how I get it, I just tried it and it's fine, > where to get that information remains then a mystery to me. If you're using Nios 5.1 and the 1s40 standard configuration, your flash base address should be 0000_0000. The best bet is to follow mountain8848's suggestions and review your ptf file. > Bank# 1: Size: 0 KB in 0 Sectors Check your flash_init() routine in board/altera/common/AMDLV065D.c -- you probably still have the routine contents commented out -- I believe that's what I suggested you do to get started on the other board you were using (since you were using a different flash device). Normally, u-boot will report an error if flash_init() reports zero memory. Regards, --Scott
