20 years agoU-BOOT !!!!!!!!!!!!
Hi http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/wacko.gif , that u-boot is really driving me crazy. This is what I've done: 1- Compiled u-boot (got the .bin and the .srec)...
20 years agoHi mountain8848,
<div class='quotetop'>QUOTE </div> --- Quote Start --- Do you just develop SW in NiosII system? Who develops NiosII in Quartus/SOPC builder?[/b] --- Quote End --- ?????????????????????????? <div class='quotetop'>QUOTE </div> --- Quote Start --- All informatioins about modules of NiosII, including flash, SDRAM..., can be found in SOPC builder.[/b] --- Quote End --- I told that when I open the standard reference design in SoPC builder, I found the flas adress at 0x00000000 which is not correct! <div class='quotetop'>QUOTE </div> --- Quote Start --- The file-- <NiosII Name>.ptf records all information about "HW" of NiosII system. Yes, of course the BASE ADDRESS. [/b] --- Quote End --- I checked that out and you're right, I found the following REFDES U5
base = "0x00800000";
} 0x00800000 is the right base adress. <div class='quotetop'>QUOTE </div> --- Quote Start --- <u-boot-src>/include/configs/"board".h should deal with the information manually.[/b] --- Quote End --- That's what I found: /*------------------------------------------------------------------------
* MEMORY BASE ADDRESSES
*----------------------------------------------------------------------*/# define CFG_FLASH_BASE 0x00000000 /* FLASH base addr */# define CFG_FLASH_SIZE 0x00800000 /* 8 MByte */# define CFG_SDRAM_BASE 0x01000000 /* SDRAM base addr */# define CFG_SDRAM_SIZE 0x01000000 /* 16 MByte */# define CFG_SRAM_BASE 0x02000000 /* SRAM base addr */# define CFG_SRAM_SIZE 0x00100000 /* 1 MB */ And again the base adress is wrong!!!!!!!!!!!!!!!!!!!!!!!! I concluded that I got to look only in the .ptf file.
