20 years agoU-BOOT !!!!!!!!!!!!
Hi http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/wacko.gif , that u-boot is really driving me crazy. This is what I've done: 1- Compiled u-boot (got the .bin and the .srec)...
20 years agoHi MFM,
==> flinfo
Bank# 1: Size: 0 KB in 0 Sectors
Sector Start Addresses: It's time to implement your flash driver. If you have a CFI flash (and are _not_ using a data cache) you may want to try the default CFI flash driver. However, depending on the command set and your flash geometry you may have to disable the toggle bit polling (since it won't work with avalon). Otherwise, you can grab an existing driver from another project. Please post your flash configuration (and part numbers) and I'll see if there's one I can recommend. Best Regards, --Scott
