20 years agoU-BOOT !!!!!!!!!!!!
Hi http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/wacko.gif , that u-boot is really driving me crazy. This is what I've done: 1- Compiled u-boot (got the .bin and the .srec)...
20 years ago --- Quote Start --- originally posted by mfm@Apr 30 2006, 10:01 AM hi hippo,
<div class='quotetop'>quote
--- quote end ---
--- quote start ---
http://www.denx.de/wiki/view/dulg/linuxnfsroot (http://www.denx.de/wiki/view/dulg/linuxnfsroot) --- Quote End --- That doesn't explain what's the nuance between flash and ram in using uboot nor how to get their adresses. <div class='quotetop'>QUOTE </div> --- Quote Start --- But nios2 uclinux won't expect kernel parameters from boot loader, so it might not work.[/b] --- Quote End --- Encouraging http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/laugh.gif <div class='quotetop'>QUOTE </div> --- Quote Start --- boot with initramfs, mount nfs, then switch root to nfs.[/b] --- Quote End --- How to do so, and please could you explain what are initramfs and initrd. <div class='quotetop'>QUOTE </div> --- Quote Start --- You may find an example from www.ltsp.org lbe source cvs, initramfs_src/initramfs_tree/initramfs_tree/init You may take a trial of the ltsp4.2 on PCs to get some idea of it.[/b] --- Quote End --- ????????????? BTW, when you talk in other posts about custom board, do you mean a board you make by yourself with different components you routed on ? Warm Regards <div align='right'><{post_snapback}> (index.php?act=findpost&pid=14855)</div> [/b] --- Quote End --- A custom board is a board that is different from the dev board. It is a product, not for development and prototyping. The LTSP is a project which takes use of tftpboot and nfs root to remote boot diskless Linux PC. We use LTSP to run all the PCs in our company, except for the ones to run quartus. As I have said, you need the Linux know-how to success on nios2 Linux. If you take a trial on it, you can learn a lot, what is necessary for you to root nfs on nios2. So I strongly recommand LTSP as a case study. About u-boot, did you walk through the wiki? did you step into the sources? It would be nice if there is a step-by-step guide, but before we have one, you can find the way and help others in the future. I was a newbie to uClinux, too. I wanted to run uClinux on my nios2 board, which is very different from dev board. There was no cfi flash for mtd. I tried and failed a lot. It was a hard time, but I didn't give up. Finally I worked out the initramfs. And later I wrote the buildroot guide. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
