20 years agoU-BOOT !!!!!!!!!!!!
Hi http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/wacko.gif , that u-boot is really driving me crazy. This is what I've done: 1- Compiled u-boot (got the .bin and the .srec)...
20 years agoHi hippo,
<div class='quotetop'>QUOTE </div> --- Quote Start --- http://www.denx.de/wiki/view/dulg/linuxnfsroot (http://www.denx.de/wiki/view/dulg/linuxnfsroot)[/b] --- Quote End --- That doesn't explain what's the nuance between flash and ram in using uboot nor how to get their adresses. <div class='quotetop'>QUOTE </div> --- Quote Start --- But nios2 uclinux won't expect kernel parameters from boot loader, so it might not work.[/b] --- Quote End --- Encouraging http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/laugh.gif <div class='quotetop'>QUOTE </div> --- Quote Start --- boot with initramfs, mount nfs, then switch root to nfs.[/b] --- Quote End --- How to do so, and please could you explain what are initramfs and initrd. <div class='quotetop'>QUOTE </div> --- Quote Start --- You may find an example from www.ltsp.org lbe source cvs, initramfs_src/initramfs_tree/initramfs_tree/init You may take a trial of the ltsp4.2 on PCs to get some idea of it.[/b] --- Quote End --- ????????????? BTW, when you talk in other posts about custom board, do you mean a board you make by yourself with different components you routed on ? Warm Regards
