21 years agou-boot + stratix EP1S40 + issue
Hi scott, see attachment
21 years agohi haq,
> I am using u-boot-1.1.2 source from their wedsite.....I think I download it after april The reason I asked if you downloaded the tarball or directly from CVS is because the tarball for 1.1.2 was produced prior to the changes being included in the source tree. So rather than ask again, I'll just assume you're using the tarball. > I will try to use that with ur config file........then I will post my results.....any other idea? Yes, please get the u-boot sources from http://www.psyent.com/download (http://www.psyent.com/download), configure with EP1S40_config, and run that image. Otherwise, you'll be using old code ... last week there were five Nios-II patches submitted to sourceforge, which may take several months to be incorporated into the source tree. The sources at psyent already have these patches applied. Regards, --Scott
