21 years agou-boot + stratix EP1S40 + issue
Hi scott, see attachment
21 years agoHi haq,
I see what's happening to your tftpboot now: <div class='quotetop'>QUOTE </div> --- Quote Start --- #define CFG_EXCEPTION_ADDR 0x01000020[/b] --- Quote End --- <div class='quotetop'>QUOTE </div> --- Quote Start --- DK1S40 > tftpboot 0x01000000 uImage[/b] --- Quote End --- When you tftpboot to 0100_0000, you end up overwriting the exception trampoline. Then, when the timer interrupt fires, you end up in the weeds. You should be ok if you use a higher address: DK1S40> tftpboot 1100000 uImage Then you can: DK1S40> imi 1100000 DK1S40> bootm 1100000 Regards, --Scott
