21 years agou-boot + stratix EP1S40 + issue
Hi scott, see attachment
21 years agoHi haq,
Just FYI, the latest u-boot sources were posted a few days ago and are available at: http://www.psyent.com/download (http://www.psyent.com/download) And patches were submitted to the main u-boot project at sourceforge.net -- but it usually takes a few months for patches to show up. BTW: it would be very helpful if you downloaded these sources and gave it a quick try using the EP1S40_config. > It's sitting for ever.......I don't know where I am doing wrong...... You might want to check all of your network settings and your tftp server configuration. Your mac address in your environment is different than the one used by tftpboot. If you need a test mac address, you can use the gen_eth_addr tool that comes with u-boot ... it will generate a locally-administered mac for you. > BTW...I can't progam flash memory of my EP1s40 board using ur instruction......becuase I can't > use nios2-console program ..it can't load the port driver... tftpboot is the fastest way to download you images ... but that's not working for you at the moment ... so you can use the loadb command with kermit to get your image into ram. Just be careful not to download over the exception trampoline ;-) Regards, --Scott
