21 years agoU-Boot : 'make' problem
I'm trying to compile a Uboot package in order to upload the .srec file to the NIOSII Cyclone board. My problem is that "make" command terminates with this message :(...)
make: Entering directory `/cygdrive/c/altera/kits/nios2/examples/uboot/u-boot
-1.1.2/post/cpu'
make: `.depend' is up to date.
make: Leaving directory `/cygdrive/c/altera/kits/nios2/examples/uboot/u-boot-
1.1.2/post/cpu'
make -C tools all
-1.1.2/tools'
gcc -Wall -pedantic -idirafter ../include -DTEXT_BASE=0x018e0000 -DUSE_HOSTCC -O
-c -o img2srec.o img2srec.c
In file included from /usr/include/sys/unistd.h:9,
from /usr/include/unistd.h:6,
from img2srec.c:61:
/usr/include/sys/types.h:106: conflicting types for `int8_t'
/usr/include/stdint.h:38: previous declaration of `int8_t'
/usr/include/sys/types.h:108: warning: redefinition of `int16_t'
/usr/include/stdint.h:39: warning: `int16_t' previously declared here
/usr/include/sys/types.h:110: warning: redefinition of `int32_t'
/usr/include/stdint.h:40: warning: `int32_t' previously declared here
/usr/include/sys/types.h:112: warning: redefinition of `int64_t'
/usr/include/stdint.h:45: warning: `int64_t' previously declared here
make: *** Error 1
1.1.2/tools'
make: *** Error 2 It seems that these variables are overlaping each others. (I've entered "make dk1c20_config" before and everything went ok) Thanks alot, Max18 Replies
Well, sorry I had not checked everything in the PK1C20.h, some addresses were incompatible. It is fixed.
When I get the prompt, I get this :
Is the warning important, what CRC is it about ? ThanksU-Boot 1.1.2 (Apr 19 2005 - 16:56:44) CPU : Nios-II SYSID : 192c0526, Thu Nov 25 09:37:20 2004 BOARD : Psyent PK-1C20 *** Warning - bad CRC, using default environment ==> - Altera_Forum
Max,
Great to hear things are working :-) > Is the warning important, what CRC is it about ? u-boot maintains environment variables in a flash sector. The default for the Altera Cyclone devkit is at 0x0002_0000 (3rd sector). When u-boot starts up it attempts to read the environment variables from this sector ... but runs a 32-bit CRC to ensure integrity. To get rid of the warning you can simply issue the 'saveenv' command. BUT BE CAREFUL ... if you already have something else saved in that sector, (like uClinux) ... you might want to re-configure the environment address (include/configs/PK1C20.c -- see the CFG_ENV_ADDR macro). Best Regards, --Scott - Altera_Forum
(Thanks for your precise details, Scott.)
Hello, me _again_ with my uboot problems http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/laugh.gif I've followed all the instructions given with U-BOOT in order to load my .bin into flash.
But when I restart am I supposed to have a sort of u-boot config prompt ? For the moment I have nothing. It says in doc that normally uboot starts automatically (because at 0x00). Ive searched troughout the net for docs about U-BOOT implementation but found nothing really interesting at this stage. Another thing : "bootm X" command returns(...) ==> cp.b 800000 0 1bdac Copy to Flash... done
What does it mean ? If someone can help, thanks. Max==> bootm 0# # Booting image at 00000000 ... Bad Magic Number - Altera_Forum
Hi Max,
> But when I restart am I supposed to have a sort of u-boot config prompt ? Yes. Normally, u-boot is stored in flash at the reset address. At startup, u-boot copies itself to SDRAM (in this case 018e_0000), then jumps into SDRAM. From there, everything is the same. A few things to check if u-boot doesn't start on reset/power-on: 1. Make sure u-boot is stored at the actual reset address. 2. When saving u-boot to flash ... make sure you write the entire image. If you use loadb/loads to download the binary/srec, the actual size of the binary will be reported -- use the reported size. 3. To check the binary image you downloaded to SRAM, you can just use the 'go' command. Based on your last post, you would execute: ==> go 800000 Or to confirm that the image you stored in flash behaves properly: ==> go 0 If your new image doesn't run ... you have other problems ;-) > Another thing : "bootm X" command returns > ... The magic number is invalid in the image header at address 0x0.: The bootm command is used to boot a u-boot image file generated with the mkimage utility (it's not the same as the 'go' command). The bootm command does the following: 0. Checks the header magic number. 1. Performs a 32-bit CRC check of the image header. 2. Performs a 32-bit CRC check of the image data. 3. Executes other consistency checks (e.g. image type, architecture, etc). 4. Optionally decompresses the data. 5. Relocates the data to the load address. 6. Disables interrupts. 7. Finally, jumps to entry point address. So, it's normally used to boot a gzipped linux kernel image. > ... > docs about U-BOOT implementation > ... This has information for a PowerPC-based board, but it's loaded with target-independent info as well: http://www.denx.de/twiki/bin/view/dulg/uboot (http://www.denx.de/twiki/bin/view/dulg/uboot) Regards, --Scott - Altera_Forum
I checked all your precious advices then I got this :
then ... nothing. The processor hangs, nothing else possible than reseting. Damn I must have a problem with my .bin as the one I had with my .srec !==> go 800000# # Starting application at 0x00800000 ... - Altera_Forum
Egads!!! Looks like like most of the addresses have changed in the
standard example since 4.1/Nios-II 1.0!!! That explains why you had to change all the addrs ... sorry about not noticing that, Max. So ... looks like the SRAM has moved as well ... so the quick-start info in the README needs to be updated. When you download, you'll have to do something like: ==> loadb 2000000 ... ==> cp.b 2000000 0 <some hex count> --Scott - Altera_Forum
God yes it's working http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/laugh.gif
Infinite thanks ! - Altera_Forum
Great! Hopefully, the sources at psyent will be updated soon 8-P
