21 years agoU-Boot : 'make' problem
Hello, I'm trying to compile a Uboot package in order to upload the .srec file to the NIOSII Cyclone board. My problem is that "make" command terminates with this message : (...)
ma...
21 years agoHi Max,
> ... but I don't get the u-boot prompt in my terminal. It freezes. What terminal software are you using? Do you have the comm parameters set for 115200,N,8,1? > Is it normal that the downloaded size is inferior to the .srec file size ? Yes ... an srec will be at least twice the size of its associated binary. > Do I have to erase the uClinux in order to keep the processor blank of > duties before d/l ? No. u-boot should be linked to an SDRAM/SRAM address. When you download it, the -g option will will cause u-boot to be executed. BTW: Which Cyclone board are you using? --Scott
