12 years agoTwo processors with onchip memory
Hi, I am developing a project with two processors and I'm just trying to send data from pc to master cpu through uart and then from master send that data to slave cpu and then back to pc thoug...
12 years agoThanks for the reply. Can you elaborate more on the dual-port RAM please. Also, with one system and having two cpu's along with two uarts and onchip memory all within the same qsys, shouldn't I be able to send data through the uart to cpu1 and then have cpu1 send that data to cpu2 and back to pc with the uart? That loop works with one cpu but when I add both I don't get anything back on pc. Within eclipse I can see that the letters are being transmitted when I'm sending using tera term but don't see anything back. And I believe the firmware within quartus is correct with my board. I'm using the uart registers to wait for character and then transmit.
Any help is appreciated.
