20 years agotwo cpus, uClinux on cpu1
I've got a design with two nios2 cpus. The idea is that cpu1 runs uClinux to provide a webserver front end, whilst cpu2 is working with some custom on-chip hardware. I 've been able to get ...
20 years agoHere is the correct syntax. I did not understand that --device is not the cpu.
(Background, design with two nios2 cpus. cpu1 to run uClinux, zImage file made using Linux toolchain, cpu2 to run stand alone C application, image is (say) cpu2code.elf made using nios2 IDE under Windows. ) In Windows launch nios2 shell. [SOPC Builder]$ nios2-download --device 1 --instance 2 -g cpu2code.elf cpu2 application starts to run [SOPC Builder]$ nios2-download --device 1 --instance 1 -g zImage [SOPC Builder]$ nios2-terminal /> (prompt from uClinux running on cpu1)
