There is the header that I generated from DE2_115_SOPC.sopc (from DE2_115_NIOS_HOST_MOUSE_VGA.qar) by "sopc-create-config-files" (from http://www.alterawiki.com/wiki/dasuboot)
And there are different addresses. For example: --- Quote Start ---# ifndef _M_H_# define _M_H_ /* generated from DE2_115_SOPC.sopc */ /* cpu.data_master is a altera_nios2 */# define CONFIG_SYS_CLK_FREQ 0# define CONFIG_SYS_RESET_ADDR 0xca604000# define CONFIG_SYS_EXCEPTION_ADDR 0xca604020# define CONFIG_SYS_ICACHE_SIZE 4096# define CONFIG_SYS_ICACHELINE_SIZE 32# define CONFIG_SYS_DCACHE_SIZE 4096# define CONFIG_SYS_DCACHELINE_SIZE 32# define IO_REGION_BASE 0xe0000000 /* timer_0.s1 is a altera_avalon_timer */# define CONFIG_SYS_TIMER_BASE 0xea60a400# define CONFIG_SYS_TIMER_IRQ 0# define CONFIG_SYS_TIMER_FREQ 0 /* sdram.s1 is a altera_avalon_new_sdram_controller */# define CONFIG_SYS_SDRAM_BASE 0xc0000000# define CONFIG_SYS_SDRAM_SIZE 0x08000000 /* onchip_mem.s1 is a altera_avalon_onchip_memory2 */# define ONCHIP_MEM_BASE 0xea604000 /* touch_panel_pen_irq_n.s1 is a altera_avalon_pio */# define TOUCH_PANEL_PEN_IRQ_N_BASE 0xe8010000 /* I2S_ctrl.avalon_slave is a Audio */# define I2S_CTRL_BASE 0xe8000600 /* sgdma_tx.csr is a altera_avalon_sgdma */# define CONFIG_SYS_ALTERA_TSE_SGDMA_TX_BASE 0xe8702400 /* lcd.control_slave is a altera_avalon_lcd_16207 */# define LCD_BASE 0xe80000e0 /* ISP1362.hc is a ISP1362_IF */# define ISP1362_BASE 0xea60a450 /* pio_switch.s1 is a altera_avalon_pio */# define PIO_SWITCH_BASE 0xe80000c0 /* ISP1362.dc is a ISP1362_IF */# define ISP1362_BASE 0xea60a458 /* mmc_spi.spi_control_port is a altera_avalon_spi */# define MMC_SPI_BASE 0xe8000120# define CONFIG_SYS_ALTERA_SPI_LIST { MMC_SPI_BASE }# define CONFIG_ALTERA_SPI# define CONFIG_CMD_SPI# define CONFIG_CMD_MMC# define CONFIG_MMC# define CONFIG_GENERIC_MMC# define CONFIG_CMD_MMC_SPI# define CONFIG_MMC_SPI# define CONFIG_MMC_SPI_BUS 0# define CONFIG_MMC_SPI_CS 0# define CONFIG_MMC_SPI_SPEED 30000000# define CONFIG_MMC_SPI_MODE SPI_MODE_3# define CONFIG_CMD_FAT# define CONFIG_DOS_PARTITION /* touch_panel_spi.spi_control_port is a altera_avalon_spi */# define TOUCH_PANEL_SPI_BASE 0xe8011000 /* tse_mac.control_port is a triple_speed_ethernet */# define CONFIG_SYS_ALTERA_TSE_MAC_BASE 0xe8702800# define CONFIG_SYS_ALTERA_TSE_RX_FIFO 2048# define CONFIG_SYS_ALTERA_TSE_TX_FIFO 2048# define CONFIG_ALTERA_TSE# define CONFIG_MII# define CONFIG_CMD_MII# define CONFIG_SYS_ALTERA_TSE_PHY_ADDR 18# define CONFIG_SYS_ALTERA_TSE_FLAGS 0 /* pio_red_led.s1 is a altera_avalon_pio */# define PIO_RED_LED_BASE 0xe80000b0 /* sgdma_rx.csr is a altera_avalon_sgdma */# define CONFIG_SYS_ALTERA_TSE_SGDMA_RX_BASE 0xe8702000 /* SEG7.s1 is a SEG7_IF */# define SEG7_BASE 0xe8000080 /* ps2_keyboard.avalon_ps2_slave is a altera_up_avalon_ps2 */# define PS2_KEYBOARD_BASE 0xe8000158 /* sysid.control_slave is a altera_avalon_sysid */# define CONFIG_SYS_SYSID_BASE 0xe8000150 /* timer_stamp.s1 is a altera_avalon_timer */# define CONFIG_SYS_TIMER_BASE 0xea60a420# define CONFIG_SYS_TIMER_IRQ 1# define CONFIG_SYS_TIMER_FREQ 0 /* ps2_mouse.avalon_ps2_slave is a altera_up_avalon_ps2 */# define PS2_MOUSE_BASE 0xe8000160 /* pio_button.s1 is a altera_avalon_pio */# define PIO_BUTTON_BASE 0xe80000d0 /* I2C_0.avalon_slave is a I2C_Master */# define I2C_0_BASE 0xe8000100 /* dma_0.control_port_slave is a altera_avalon_dma */# define DMA_0_BASE 0xe8000000 /* jtag_uart_0.avalon_jtag_slave is a altera_avalon_jtag_uart */# define CONFIG_SYS_JTAG_UART_BASE 0xea60a440 /* uart_0.s1 is a altera_avalon_uart */# define CONFIG_SYS_UART_BASE 0xe8000060# define CONFIG_SYS_UART_FREQ 0# define CONFIG_SYS_UART_BAUD 115200 /* eth_ocm_0.control_port is a eth_ocm */# define CONFIG_SYS_ETHOC_BASE 0xe8020000# define CONFIG_ETHOC /* SVGA_sgdma.csr is a altera_avalon_sgdma */# define CONFIG_SYS_ALTERA_TSE_SGDMA_TX_BASE 0xea60a000 /* cfi_flash.s1 is a altera_avalon_cfi_flash */# define CONFIG_SYS_FLASH_BASE 0xe9000000# define CONFIG_FLASH_CFI_DRIVER# define CONFIG_SYS_CFI_FLASH_STATUS_POLL /* fix amd flash issue */# define CONFIG_SYS_FLASH_CFI# define CONFIG_SYS_FLASH_USE_BUFFER_WRITE# define CONFIG_SYS_FLASH_PROTECTION# define CONFIG_SYS_MAX_FLASH_BANKS 1# define CONFIG_SYS_MAX_FLASH_SECT 1024 /* pio_green_led.s1 is a altera_avalon_pio */# define PIO_GREEN_LED_BASE 0xe80000a0 /* onchip_memory2_0.s1 is a altera_avalon_onchip_memory2 */# define ONCHIP_MEMORY2_0_BASE 0xea608000 /* altpll_0.pll_slave is a altpll */# define ALTPLL_0_BASE 0xe8000040 # endif /* _M_H_ */
--- Quote End --- but from this file:pio_red_led: BASE = 0x0800_00b0, END = 0x0800_00bf
which adresses are correct? because i tried to use your adresses but it doesn`t work. there is code that i tried to use to turn on leds (based on the code that I found here http://lists.rocketboards.org/pipermail/nios2-dev/2012-september/006448.html ):/* pio_red_led.s1 is a altera_avalon_pio */# define PIO_RED_LED_BASE 0xe80000b0# include <stdio.h> # include <stdlib.h> # include <unistd.h> # include <sys/mman.h> # include <sys/types.h> # include <sys/stat.h> # include <fcntl.h> # include <errno.h> # define GPO_BASE 0x080000b0 //Absolute Base address # define GPO_LEN 16 //Span of register to access int main(void) { int memfd; size_t map_len; void *ts_my; void *mapped; unsigned int pgoff; int value=0; memfd = open("/dev/mem", O_RDWR | O_SYNC ); if (memfd < 0) { printf("Cannot open /dev/mem\n"); exit(1); } pgoff = (unsigned int) (GPO_BASE & (sysconf(_SC_PAGE_SIZE)-1)); map_len = GPO_LEN + pgoff; mapped = mmap(NULL, map_len , (PROT_READ | PROT_WRITE),MAP_SHARED, memfd, GPO_BASE - pgoff); if (mapped == MAP_FAILED ) { printf("Cannot map registers\n"); printf("Can't mmap %i = %s\n", errno, strerror(errno)); } close(memfd); ts_my = mapped + pgoff; //attempt to write to data register to switch on leds *(unsigned*)(ts_my+0x0) = 0xffff; //value= *(unsigned*)(ts_my); //to read //printf("%d\n",value); printf("mapped:%x pgoff:%x ts_my=%p\n",(unsigned int)mapped,(unsigned int)pgoff, ts_my); printf("memorymapped register add:%x\n",(unsigned long *) ts_my); printf("memorymapped register value:%u\n",*(unsigned long *) ts_my); munmap(mapped, map_len); return EXIT_SUCCESS; } - Altera_Forum
--- Quote Start --- which adresses are correct? because i tried to use your adresses but it doesn`t work. --- Quote End --- You must know the meaning of addresses, "physical" and "virtual" ones. And also you must know the meaning of modes, "kernel mode" and "user mode".
I mean those as physical ones. Kazupio_red_led: BASE = 0x0800_00b0, END = 0x0800_00bf - Altera_Forum
--- Quote Start --- Hi, You must know the meaning of addresses, "physical" and "virtual" ones. And also you must know the meaning of modes, "kernel mode" and "user mode".
I mean those as physical ones. Kazu --- Quote End --- Thanks. Ok. But i dont try to write directly in physical address. In code i put physical adress in mmap and it should give me virtual address that i can use to get access to registers. If i write 0x1 to base address of red_led, will firts red led swith on? And also i think to try to recompile linux, to be able to write drivers, e.t.c. Is there an instruction how to compile linux with the same abilities (vga, usb, e.t.c.)?pio_red_led: BASE = 0x0800_00b0, END = 0x0800_00bf - Altera_Forum
--- Quote Start --- Ok. But i dont try to write directly in physical address. In code i put physical adress in mmap and it should give me virtual address that i can use to get access to registers. --- Quote End --- Even the kernel can't use physical addresses directly. You must use those as 'kernel mode virtual addresses'. --- Quote Start --- And also i think to try to recompile linux, to be able to write drivers, e.t.c. Is there an instruction how to compile linux with the same abilities (vga, usb, e.t.c.)? --- Quote End --- Frankly speaking, I think that you don't have enough knowledge to make a driver yet. Kazu - Altera_Forum
--- Quote Start --- Hi, Even the kernel can't use physical addresses directly. You must use those as 'kernel mode virtual addresses'. --- Quote End --- I have never heard about "kernel mode virtual addresses". I cant find information about it. Can you give me reference? Also i have solved my problems with ethernet. I didn`t notice this sentence.
About addresses: I have tried to use addresses that was generated by "sopc-create-config-files" tool. And it works.And set the jumper switch 'JP1' to '2-3 short', because this example uses MII mode for the Ether Phy's interface. - Altera_Forum
--- Quote Start --- I have never heard about "kernel mode virtual addresses". I cant find information about it. Can you give me reference? --- Quote End --- Please refer http://www.altera.com/literature/hb/nios2/n2cpu_nii51003.pdf table 3-2 at pp.3-4. In this case, you must use the partition 'I/O' and note that these ranges are all 'virtual address' ones. --- Quote Start --- About addresses: I have tried to use addresses that was generated by "sopc-create-config-files" tool. And it works. --- Quote End --- If your purpose is only to drive leds etc., it is the easiest way. But if your purpose is to learn and make some Linux drivers, you must learn more. Kazu - Altera_Forum
Kazu, thank you.
There is a LCD driver( http://www.alterawiki.com/wiki/lcd_16207 ). Can I compile It for this linux without recompiling the kernel? - Altera_Forum
--- Quote Start --- There is a LCD driver( http://www.alterawiki.com/wiki/lcd_16207 ). Can I compile It for this linux without recompiling the kernel? --- Quote End --- It's possible to compile driver modules without recompiling the kernel each time, but you may once compile it and make the 'linux-2.6.x' folder. The attached file includes the sample code of LCD 16207. Please extract it and copy 'lcd_16207.ko' to your SD or somewhere. To load the module, type
('modprobe' will not work). After the verbose messages, if you getinsmod lcd_16207.ko
then make a 'device file' by typing... reltype 12 0x38 name:<device_release> Applying relocate section 16 to 15 reltype 12 0xbc name:<init_module> reltype 12 0x104 name:<cleanup_module> Device /dev/lcd16207 registered
and you can send your message to the LCD bymknod /dev/lcd16207 c 250 0
. If you want to recompile this module, please refer the header comments of the source file 'lcd_16207.c'. Kazuecho "Hello LCD!" > /dev/lcd16207 - Altera_Forum
Kazuyasu, thank you.
Module works. But I can`t found where i can download 'linux-2.6.x'. I found this instruction http://www.alterawiki.com/wiki/installnios2linux . And according to it I downloaded sources from ftp://ftp.altera.com/outgoing/nios2-linux/20120802/ There are linux 2.6 sources. Are these sources suitable for compiling module? And which sources were used for compiling VEEK/t-Pad linux ? - Altera_Forum
--- Quote Start --- Module works. But I can`t found where i can download 'linux-2.6.x'. I found this instruction http://www.alterawiki.com/wiki/installnios2linux . And according to it I downloaded sources from ftp://ftp.altera.com/outgoing/nios2-linux/20120802/ There are linux 2.6 sources. Are these sources suitable for compiling module? And which sources were used for compiling VEEK/t-Pad linux ? --- Quote End --- The folder 'linux-2.6.x' is generated when you compile the kernel. To compile your modules, you don't need all files which are included in the folder 'linux-2.6.x'. So, I'm now gathering the necessary files to compile modules, please wait for a while. Kazu
