13 years agoTutorial Video: How to boot uClinux on NIOS II Processor with MMU
Hi everyone I record a tutorial video about how to boot uclinux on Nios II Processor with MMC I used DE2-115 as reference but you can use any board that you like Feel free to contact me if you...
12 years ago --- Quote Start --- Hi, If your board is DE2-115, please visit the page http://www.alterawiki.com/wiki/linux_with_mmu_on_veek/t-pad and refer the section No.8. --- Quote End --- thank you. But I have an issue with this instruction. What i did: 1) connected my de2-115 board to my PC via "usb blaster" port. 2) downloaded this http://www.alterawiki.com/wiki/file:d115_selector.tar.gz 3) in NIOS commend shell
name@idea-PC /cygdrive/c/altera/13.1
$ quartus_pgm.exe -m jtag -c USB-Blaster -o "p;tPad_Selector.sof"
Info: *******************************************************************
Info: Running Quartus II 32-bit Programmer
Info: Version 13.1.0 Build 162 10/23/2013 SJ Web Edition
Info: Copyright (coffee) 1991-2013 Altera Corporation. All rights reserved.
Info: Your use of Altera Corporation's design tools, logic functions
Info: and other software and tools, and its AMPP partner logic
Info: functions, and any output files from any of the foregoing
Info: (including device programming or simulation files), and any
Info: associated documentation or information are expressly subject
Info: to the terms and conditions of the Altera Program License
Info: Subscription Agreement, Altera MegaCore Function License
Info: Agreement, or other applicable license agreement, including,
Info: without limitation, that your use is for the sole purpose of
Info: programming logic devices manufactured by Altera and sold by
Info: Altera or its authorized distributors. Please refer to the
Info: applicable agreement for further details.
Info: Processing started: Fri Mar 14 14:41:44 2014
Info: Command: quartus_pgm -m jtag -c USB-Blaster -o p;tPad_Selector.sof
Info (213045): Using programming cable "USB-Blaster "
Info (213011): Using programming file tPad_Selector.sof with checksum 0x00BBDF04
for device EP4CE115F29@1
Info (209060): Started Programmer operation at Fri Mar 14 14:41:49 2014
Info (209016): Configuring device index 1
Info (209017): Device 1 contains JTAG ID code 0x020F70DD
Info (209007): Configuration succeeded -- 1 device(s) configured
Info (209011): Successfully performed operation(s)
Info (209061): Ended Programmer operation at Fri Mar 14 14:41:55 2014
Info: Quartus II 32-bit Programmer was successful. 0 errors, 0 warnings
Info: Peak virtual memory: 191 megabytes
Info: Processing ended: Fri Mar 14 14:41:55 2014
Info: Elapsed time: 00:00:11
Info: Total CPU time (on all processors): 00:00:04
After that I had white screen on my vga monitor. 4)
$ nios2-flash-programmer.exe --epcs --base=0x0a001800 tPad_Selector.flash
Using cable "USB-Blaster ", device 1, instance 0x00
Resetting and pausing target processor: OK
No EPCS layout data - looking for section
Unable to use EPCS device
Leaving target processor paused
There is an error:
