13 years agoTSE TCP Stack problem
Hi, I have experienced a weird problem. The system is based on CycloneIII, TSE IP is connected to Marvell 88E6185 multiports switch (Port 9 as Phy). The system can send out UDP/IP and Ping. It ...
13 years agoCould you use a Ethernet sniffing tool such as Wireshark and see what happens? Especially if you have some missed packets and retransmissions, it could help understand what is happening.
What kind of system is it sending TCP packets to?
