15 years ago
TSE_MAC and memory
Hi Guys,
I've been building on examples and built a functioning ethernet. I can use the Nios for TCP TX/RX and i have interfaced some HDL for direct UDP TX.
I'm currently developing on a DE2-115 and i'm merging this and the D5M camera example. I'll be building my own board soon.
Problem is both use the SDRAM in their isolation and i need to merge.
de2-115 has
- sdram 2x64mb(16bit wide) used together as 32bit wide.
- sram - 2mb
1. how can i determine how much memory the tse_mac needs?
2. does the niche stack use the sram?
regarding point 1: the example i took just used the full 128mb and the BSP says it uses it all, but i imagine that more means it allocates it all.
[update]
point 2: I've tried to remove the SRAM in the past but my ethernet initialisation gets stuck after
INFO    : TSE MAC 0 found at address 0x0c042000
INFO    : PHY Marvell 88E1111 found at PHY address 0x10 of MAC Group
INFO    : PHY - Automatically mapped to tse_mac_device
INFO    : PHY - Restart Auto-Negotiation, checking PHY link...
INFO    : PHY - Auto-Negotiation PASSED
According to the BSP linker, nothing seems to link it.
I've left the pin assignments, but i've removed it from the Qsys and commented it out of the module instantiation.
I've checked what i can timer wise. I also remember the first time i tried to do this, i did a signal tap on the sram and didn't pick up any enabling of it, or changes in data. But i may have missed something there.
Thanks in Advance for any comments and help.
