15 years agoTSE_MAC and memory
Hi Guys, I've been building on examples and built a functioning ethernet. I can use the Nios for TCP TX/RX and i have interfaced some HDL for direct UDP TX. I'm currently developing on a...
15 years agoThen add on-chip memory instead of SDRAM, but it has to be big enough, to fit all the Nios software. If You'll use TCP/IP stack and/or RTOS, I doubt You'll get Your work done.
