15 years agoTSE_MAC and memory
Hi Guys, I've been building on examples and built a functioning ethernet. I can use the Nios for TCP TX/RX and i have interfaced some HDL for direct UDP TX. I'm currently developing on a...
15 years agoNo, the stack use memory allocation, not the particular device. Remove SRAM in SOPC, choose proper vectors for Nios, regenerate base addresses and regenerate the system. Also check if Your timers are correct.
