13 years agoTSE Gigabit will not generate TX pause frames
Hello, I have done everything I can see to try for over a day now but have been unable to get pause frames to be transmitted on a Gigabit link. Even with XOFF_GEN set in the command register n...
13 years ago --- Quote Start --- Changing the advertised TCP window will only help if there is only a single connection. --- Quote End --- Yes of course. In my use case I had only one TCP connection that required a high bandwidth at any given time so I didn't really bother about that fact. But it can be a problem in other use cases. --- Quote Start --- Can I have the SGDMA collect up to 8 packets before interrupting? --- Quote End --- IIRC if you create a chain with 8 descriptors (plus a 9th with owned_by_hw to stop the transfer) you can configure the SGDMA to generate an interrupt at the end of the chain rather than after each descriptor is processed. Of course it will require to modify the driver a bit.
