14 years agoTSE and UDP packet offload
Hello, I'm using hardawre Nios II UDP Offload System with nios2-uClinux here is the soft configuration : --- Quote Start --- ..... const char *addr[] = { ...
14 years agoYes this is the right option. What you report is strange, it's almost as if you had two pad insertions.
Could you put a Signaltap probe on the Avalon Stream going to the TSE, to check what's going in and how much pagding you have in front of the packet?
