14 years agoTSE and UDP packet offload
Hello, I'm using hardawre Nios II UDP Offload System with nios2-uClinux here is the soft configuration : --- Quote Start --- ..... const char *addr[] = { ...
14 years agoIt is necessary if you enable the pad option in the TSE settings in Sopc builder/QSys. This option makes life easier for some drivers. You can disable the option in the TSE and not use the alignment_pad_inserter component, but then you might run into trouble if you use the TSE with software.
