14 years agoTSE and UDP packet offload
Hello, I'm using hardawre Nios II UDP Offload System with nios2-uClinux here is the soft configuration : --- Quote Start --- ..... const char *addr[] = { ...
14 years agothe problem come from alignment_pad_inserter component, it inserts two pad bytes at the beginning
is it necessary to use it?
